12748 Discussions
How to use small driver of JTAG_UART
Dear All,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
  &#9632; Specify the preprocessor option
-DALTERA_AVALON_JTAG_UART_SMALL. You can use this option if
you want the small, polled implementation of the JTAG UART
driver, but you do not want to affect the drivers for other devices.[/b]
--- Quote End ---
I find the information above from Altera Embedded Peripherals Handbook.pdf--page68.
But I don&#39;t know how to implement it.
I have tried define ALTERA_AVALON_JTAG_UART_SMALL in project properties:
C/C++ Build->Tool Settings->Nios II Compiler->Preprocessor->Defined Symbols
But after recompiling project, I found that it didn&#39;t take effect. JTAG_UART still work in interrupt-driven way. Also I can step into altera_avalon_jtag_uart.c to prove that fast driver is in use.
I do not want to affect the drivers for other devices when use small driver of JTAG_UART. So I need to use ALTERA_AVALON_JTAG_UART_SMALL symbol.
Anyone help?
David
I have solved this issue.
--- Quote Start ---
C/C++ Build->Tool Settings->Nios II Compiler->Preprocessor->Defined Symbols[/b]
--- Quote End ---
This operation should work on system library project but not on your application project. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/happy.gif
--- Quote Start ---
originally posted by david_cai@Jul 13 2006, 08:13 AM
i have solved this issue.
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
i have tried define altera_avalon_jtag_uart_small in project properties:
c/c++ build->tool settings->nios ii compiler->preprocessor->defined symbols
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16851)</div>
[/b]
--- Quote End ---
Hi David_Cai!
Another way to define ALTERA_AVALON_JTAG_UART_SMALL in Nios IDE is checked box in "System Library Properties" -> Reduce device drivers
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
