Hi everyone:
When I want to download the kernel in my DE II board, after I login the NIOS II 6.0 command shell window, I typed the command nios2-download -g zimage , I got these message, who can help me? Thanks! <div class='quotetop'>QUOTE </div> --- Quote Start --- bash: tr: command not found bash: uname: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found ------------------------------------------------ Welcome To Altera SOPC Builder Version 6.0, Built Mon Apr 24 15:26:45 PDT 2006 ------------------------------------------------ bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found ------------------------------------------------ Welcome to the Nios II Embedded Design Suite Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006 Example designs can be found in /cygdrive/c/altera/kits/nios2_60/examples ------------------------------------------------ (You may add a startup script: /cygdrive/c/altera/kits/nios2_60/user.bashrc) /cygdrive/c/altera/kits/nios2_60/examples [SOPC Builder]$ nios2-download -g zImage_de2_net bash: /cygdrive/c/altera/kits/nios2_60/bin/nios2-download: /bin/sh: bad interpre ter: No such file or directory /cygdrive/c/altera/kits/nios2_60/examples [SOPC Builder]$[/b] --- Quote End ---Link Copied
Something's wrong with your cygwin installation. It is complaining about the most simple commands in the /bin directory. Try reinstalling or fixing your path settings.
Have you installed more then one version of Quartus & Nios? (eg 5.1 & 6.0) that might be a problem for the SDK shell.- Mark as New
--- Quote Start --- originally posted by wgoossens@Jul 18 2006, 01:17 AM something's wrong with your cygwin installation. it is complaining about the most simple commands in the /bin directory. try reinstalling or fixing your path settings.
have you installed more then one version of quartus & nios? (eg 5.1 & 6.0) that might be a problem for the sdk shell.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16975)
--- quote end ---
--- Quote End --- Thanks for your reply! Maybe this problem cause of the quartus version, I install the quartus 5.1, there have no problem now!
