12748 Discussions
Problem creating external module
Hi!
I'm trying to build an external module, to use with insmod, and I'm getting some errors. I'm quite sure it is some type of Makefile error, but I haven't been able to find an example to follow it.
My Makefile is
TOPDIR = .. include $(TOPDIR)/Rules.mak PROJ_NAME = XXX_driver INSTALL_DIR = SRCDIR    = $(TOPDIR)/drv INCDIR    = $(TOPDIR)/inc OBJ    = $(SRCDIR)/$(PROJ_NAME).o CFLAGS    += -I$(INCDIR) -D__KERNEL__ -DCONFIG_MODVERSIONS all: $(OBJ) clean:     -rm -f $(OBJ) *.
and I'm getting include errors such:
c:/altera/kits/nios2q50/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/config.h:4:28: linux/autoconf.h: No such file or directory
I've seen that the linux/autoconf.h is in the build directory, but I haven't been able to include it in any correct way.
Does anybody have a working Makefile to generate external modules?
Thank you
Alex
It is sead before and I will say it again:
Developing Linux is done under Linux.
Follow the guide at the nios wiki (http://nioswiki.jot.com) and make a nice development environment under linux.
Developing a userspace program under Windoze is difficult, developing a kernel module is worse. You can simply download the binary toolchain and start programming.
Search the forum for a the Makefile. I recently posted the Makefile (and method)I always use to write my kernel modules for the NiosII.
Hope this helps!
