nios2-download
Hi everyone:
When I want to download the kernel in my DE II board, after I login the NIOS II 6.0 command shell window, I typed the command nios2-download -g zimage , I got these message, who can help me?
Thanks!
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
bash: tr: command not found
bash: uname: command not found
bash: grep: command not found
Welcome To Altera SOPC Builder
Version 6.0, Built Mon Apr 24 15:26:45 PDT 2006
Welcome to the Nios II Embedded Design Suite
Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006
Example designs can be found in
    /cygdrive/c/altera/kits/nios2_60/examples
(You may add a startup script: /cygdrive/c/altera/kits/nios2_60/user.bashrc)
[SOPC Builder]$ nios2-download -g zImage_de2_net
bash: /cygdrive/c/altera/kits/nios2_60/bin/nios2-download: /bin/sh: bad interpre
ter: No such file or directory
[SOPC Builder]$[/b]
--- Quote End ---
Something&#39;s wrong with your cygwin installation. It is complaining about the most simple commands in the /bin directory. Try reinstalling or fixing your path settings.
Have you installed more then one version of Quartus & Nios? (eg 5.1 & 6.0) that might be a problem for the SDK shell.
--- Quote Start ---
originally posted by wgoossens@Jul 18 2006, 01:17 AM
something&#39;s wrong with your cygwin installation. it is complaining about the most simple commands in the /bin directory. try reinstalling or fixing your path settings.
have you installed more then one version of quartus & nios? (eg 5.1 & 6.0) that might be a problem for the sdk shell.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16975)
--- quote end ---
--- Quote End ---
Thanks for your reply!
Maybe this problem cause of the quartus version, I install the quartus 5.1, there have no
problem now!
