12748 Discussions
How to use the niosii interrupt service program
How to use the niosii interrupt service program,where are there example???
Please see the count_binary example. It registers an interrupt handler for the buttons which change the way it counts.
thank!!!!!
i use this example but the interupt can not responde
when i press the button but the led can not change
please tell a little bit more,
what version of quartus, nios, hardware are you using
can you start the proram in debugger ?
can you set a breakpoint in the interrupt ?
does it enter the interrupt routine ?
static void handle_button_press(alt_u8 type, FILE *lcd)
/* Button press actions while counting. */
if (type == &#39;c&#39;) // <-- set breakpoint here
