12748 Discussions
How to write HAL ISRs for custom components
Hi experts,
I created a custom component in the Component Editor and added it in a system containing only the Nios II and the component. I can write data from the Nios to my component; this is working. Now I want my component to interrupt the CPU so that it reads from the component.
How can I access the Nios registers containing the information about interrupts? I read in Ch. 5 of the Nios SW Handbook about developing HAL drivers but couldnt get any information on how to register an interrupt.
Any help or hints would be appreciated...
Thanks in advance!
I also encounter problems with hardware custom components interrupts. Could someone help us ?
Thanks !
Regards.
Basically, to register your ISR you do
alt_irq_init // enable irqs in control register 3 (nios proc ref book, chapter 3)
alt_irq_register // tie your ISR
alt_irq_enable // enable your IRQ
That should work.
__________
If you want to access CPU registers, you can use functions like:
alt_irq_pending (or NIOS2_READ_IPENDING),
alt_irq_enabled, alt_irq_enable, alt_irq_disable etc
Check the alt_irq.h for the reference.
Good luck
