I2c
praveenkumar
Principiante
2.431 Visualizações
Is there any ip core support i2c communication in cyclone 3 fpga having nios 2 processor and also i have to boot the nios 2 by sampling the externally connected enable pin any one help me with this two
12 Respostas
EricMunYew_C_Intel
Moderador
2.384 Visualizações
praveenkumar
Principiante
2.379 Visualizações
Thank u.
while flashing  from onchip memory  through (usb blaster ii) in cyclone iii fpga quartus 13.1 version.
while converting hex and sof files to pof file.
error :
data overlaps between adderess 0 and 8.is coming. can u pls help me with this  error
EricMunYew_C_Intel
Moderador
2.366 Visualizações
May I know which document you followed?
praveenkumar
Principiante
2.351 Visualizações
sry for late reply ,
I,referred from  below attached document  pg no:255,5.2.1.3 could i make flash from that. pls help me
EricMunYew_C_Intel
Moderador
2.337 Visualizações
You can boot from flash, you can refer to page 219.
praveenkumar
Principiante
2.327 Visualizações
hi , i referred the document  we have an external nor flash ic  for booting .
we have on chip ram ip for copying the flash code . but  i have to boot based on external   pin .
what should be used for my project,
1. memory based boot copier
or
2. alt_load_function based
i think i had to use memcopy based boot copier because i have to boot based on external pin triggering.
so, how do i create memory based boot copier in the code .
can u give a solution .
EricMunYew_C_Intel
Moderador
2.305 Visualizações
You can load your application from external flash to on-chip RAM using boot copier.
You can refer to page 219 below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf
praveenkumar
Principiante
2.297 Visualizações
hex file generated from nios ii command shell with a width =8 and added for generation of pof file .
it showing no error pof file is generating .
while generating from make target (mem_init_generate) hex file is generating but on adding to generate pof file ( error: data in hex file overlaps between address 0 and 8)is showing.
i am toggling a pin in .sof file and another pin in .hex file . i am not added generic tristate controller and conduit bridge.
but i loaded the pof file through usb blaster  ii .
on power on pin which i toggling in .sof file is toggling but in .hex file another pin i toggled is not working
praveenkumar
Principiante
2.295 Visualizações
In our configuration msel pins are routed such that to connect active parallel  config mode.
parallel flash loader automatically accesss the flash pins why pin in hex file is not toggling. am i doing anything wrong.
praveenkumar
Principiante
2.267 Visualizações
can u provide me  procedure or an example of   how to make advanced boot copier code in c.
can u please provide the refernce  kindly its very urgent .
u r reply is very slow.
EricMunYew_C_Intel
Moderador
2.226 Visualizações
The boot copier is added in .hex when you generate it. You don't have to write it.
praveenkumar
Principiante
2.212 Visualizações
how to generate .sh file in nios ii.
okay but based on external pin basis i have to execute my code.
Responder
