12748 Discussions
IORD_16DIRECT causes 2 reads on a 16-bit data bus
A 16-bit write quite rightly performs a single write cycle. A 16-bit read performs two reads, with the next (word) address being read on the second cycle.
Why? Simplification of the bus arbiter?
Hi JasonDiplomat,
I hope you don't mind me tagging a question onto your post, but I also have this problem, but with 8-bit access and was about to start a post.
Using Quartus/Nios V5.0, and a Nios II/e CPU, I have created a component as an 8-bit avalon_tristate_slave in Memory slave mode.
When accessing this component, writes take a single bus cycle, but reads, take 4 consecuive cycles, reading from BASE to BASE + 3.
Simple code example:
volatile alt_u8 Test = 0;
*(volatile alt_u8*)BPIO_BIDIR_BASE = Test; // Takes 1 bus cycle (as expected)
Test = *(volatile alt_u8*)BPIO_BIDIR_BASE; // Takes 4 bus cycles (NOT as expected)
This does not seem logical
Can anyone explain what is going on here?
Searching the forum with the keywords „dynamic AND bus AND sizing” will help to understand the behaviour. Take the Avalon bus specification as a book with golden rules.
niosIIuser
Hi, JasonDiplomat
I confuesd the same problem, please see create a new componet(avalon tristate) (http://www.niosforum.com/forum/index.php?act=st&f=2&t=1984) POST 2
