I can install uclinux1.3 ,but can not find plugin in NIOSII IDE.
So I can not create a linux project. How to register Microtronix Plugins to nios2 IDE? Thanks!Link Copied
Assuming you installed uClinux after installing the Nios IDE, it should have automatically have registered the plugins.
Check the plugins directory in the following folder: altera\kits\nios2\bin\eclipse\plugins- Mark as New
Thanks!
Now,I find new questions: when I create a kernal project, error : =========================================== Project cannot be created Reason: Resource /kernal_1c20/build/arch/nios2nommu does not exist ===========================================- Mark as New
I also encountered the same problem "nios2nommu does not exist"
I reinstalled everything and still the same problem. I could see the directory arch/niosnommu in the uncompressed download file. Iam stuck now. Any Help please- Mark as New
I removed eveything including a older cygwin installtion (and removed all registry entry related to cygnus) . Then reinstalled Quartus 4.2 with SP1 and Nios 1.1
Now this error does not happen.
