Image of ecos
I want to know the size of ecos image with following config.
1. Basic kernal
2.Full networking support
3. SNMP Full support
4. Serial Interface support
5. red boot support
Thanks & Regards
Sudhir Khurana
The easiest way to find out is to install eCos and build the configurations that you're interested in. That way you can play around and look at, for example, the impact of adding/removing features from the network stack.
I'm currently working on porting eCOS over Versa Logic Board based on Intel Celeron Processor for my Project. I have done the necessary changes in the HAL and memory layout but I'm facing some issues in this. I have my final presentation on 21st June 2005. If you could send me the eCOS image which was ported to Intel x86(PC Motherboard), it would be exteremely useful for my Project.
Thanks & Regards
Prajeesh
This is a Forum for the port of eCos to the Nios Processor.
So I'm afraid we have no port to an x86 motherboard.
You might try one of the eCos mailing lists which can be found at http://sources.redhat.com/ecos/ (http://sources.redhat.com/ecos/)
--- Quote Start ---
originally posted by sudhir1919@May 13 2005, 08:54 AM
i want to know the size of ecos image with following config.
1. basic kernal
2.full networking  support
3. snmp full support
4. serial interface  support
5. red boot  support
thanks & regards
sudhir khurana
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=6914)
--- quote end ---
--- Quote End ---
3. SNMP Full support----can it support v1,v2 or v3?
