kernel configure
Hello http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif
After
1--add new project in IDE
2--linux kernel project
3--Finish
message error:
project cannot created
Reason:
Resource/kernel/build/arch/nios2nommu does not exist
can you help me for this !!!!!!!!!!!!!!!!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
--- Quote Start ---
originally posted by chaouch.haithem@Apr 21 2006, 01:34 AM
hello http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ph34r.gif
  after
          1--add new project in ide
          3--finish
          message error:
                  reason:
                            resource/kernel/build/arch/nios2nommu does not exist
can you help me for this !!!!!!!!!!!!!!!!!! http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif   http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif   http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14526)
--- quote end ---
--- Quote End ---
You&#39;d better build on Linux PC, follow my guide,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174
Or,
how to run the uClinux in NIOS2 in chinese by Alex.liu.
http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52 (http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52)
I got same problem when I was using Nios ide 1.1 and uclinux_1.4 release.
I uninstalled uclinux_1.4 release and installed uclinux_1.3 release and its working fine.
Just try it once.
Ankur
Dont mix IDEs or different Cygwin installations. My advice is remove all Cygwin, Nios IDEs and Quartus from your PC, then clean the registry with regclean and install from scratch. In my case this worked.
You should really build tools and work on Linux.
There is no such trouble as nios2 or IDE version.
You should avoid spaces in the pathnames when installing the Nios tools on Windows.
But Hippo IS right.... Sooner or later you WILL move to linux &#39;cause it works WAY faster and with a lot less trouble!
