12748 토론
Information about HAL of device driver
명예로운 기여자 II
1,076 조회수
i would like to write a software for a Nios II. Where can i find more information about function of the device drivers expect for the header file. I will write a test for a CFI flash memory. I created my system in the SOPC Builder and use the altera_avalon_cfi_flash.h in the NIOS IDE. The description is not helpful in the altera_avalon_cfi_flash.h.
Thank you in advance!
0 포인트
1 응답
명예로운 기여자 II
393 조회수
--- Quote Start ---
originally posted by nero4444@Apr 2 2007, 02:17 PM
hi,
i would like to write a software for a nios ii. where can i find more information about function of the device drivers expect for the header file. i will write a test for a cfi flash memory.  i created my system in the sopc builder and use the altera_avalon_cfi_flash.h in the nios ide. the description is not helpful in the altera_avalon_cfi_flash.h.
thank you in advance!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22738)
--- quote end ---
--- Quote End ---
Maybe it was self-evident for you, that you read that already, but if not, check the Altera manual for information:
http://www.altera.com/literature/lit-nio2.jsp: (http://www.altera.com/literature/lit-nio2.jsp:)
Nios II Software Developer&#39;s Handbook
->Section II. The HAL System Library
->Chapter 5. Developing Device Drivers for the HAL (ver 7.0.0, Mar 2007, 253 KB)
0 포인트
응답
