FrameBuffer problem
hi hippo:
I try to test the FrameBuffer example as your setp,but,the system cann't be
generated.Could you give me the succuess project which can run the framebuffer!
Thanks!! My EMAIL:li8126@sin.com
--- Quote Start ---
originally posted by liuxiaoping@Mar 30 2007, 04:12 AM
hi hippo:
        i try to test the framebuffer example as your setp,but,the system cann't be
generated.could you give me the succuess project which can run the framebuffer!
thanks!!  my email:li8126@sin.com
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22659)
--- quote end ---
--- Quote End ---
to hippo
I try out to test the FrameBuffer example for days,but,there are always some problems,Could you give me your project which can run the framebuffer!So i can find my problem! Thank you very much!!My EMAIL:li8126@sin.com
There may be some problem about the ps2 component when i generate the system_0.ptf.and i use the Quartus II 5.0.below is the error:
# 2007.04.02 09:42:00 (*) Running Generator Program for VGA_0
# 2007.04.02 09:42:03 (*) Running Generator Program for ps2_0
ERROR:
In object &#39;&#39; of class e_port: can&#39;t access `vhdl_record_type&#39; field
known fields are:
_AUTOLOAD_ACCEPT_ALL
__is_inout
_creation_history
_direction
_export
_negated
_never_export
_object_list
_parent_set
_project_set
_ptf_written
_signal_list
comment
copied
declare_one_bit_as_std_logic_vector
default_value
depth
indent
isa_dummy
name
paragraph
trimmed
type
vhdl_declare_only_type
vhdl_default
width
known pointers are:
_parent
_project
keys:
_permitted
_pointers
by the way, this object is a dummy
Error: Generator program
for module &#39;ps2_0&#39; did NOT run successfully.
Where you guys getting this error:
I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer
but I ran into this error when trying to run make in the uClinux-dist/
arch/nios2nommu/drivers/altfb.c: In function `altfb_probe&#39;:
arch/nios2nommu/drivers/altfb.c:161: error: `na_vga_controller_0&#39;
undeclared (first use in this function)
arch/nios2nommu/drivers/altfb.c:161: error: (Each undeclared
identifier is reported only once
arch/nios2nommu/drivers/altfb.c:161: error: for each function it
appears in.)
make[2]: *** [arch/nios2nommu/drivers/altfb.o] Error 1
make[1]: *** [arch/nios2nommu/drivers] Error 2
Do you have the vga_controller_0 hardware in your SoPC Builder system? The software# def&#39;s are telling you that you need it. The Wiki should tell you where you can find it. If not, a quick search through the forum should yield results.
Cheers, and Good luck!
- slacker
fs/buffer.c: In function `__find_get_block_slow&#39;:
fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3)
LD fs/built-in.o
CC drivers/char/tty_io.o
In file included from include/linux/selection.h:11,
from drivers/char/tty_io.c:103:
include/linux/vt_buffer.h:18:21: asm/vga.h: No such file or directory
make[3]: *** [drivers/char/tty_io.o] &#38169;&#35823; 1
make[2]: *** [drivers/char] &#38169;&#35823; 2
make[1]: *** [drivers] &#38169;&#35823; 2
make[1]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x&#39;
make: *** [linux] &#38169;&#35823; 1
--- Quote Start ---
originally posted by feng8126@Apr 2 2007, 07:53 PM
where you guys getting this error:
i tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer
but i ran into this error when trying to run make in the uclinux-dist/
fs/buffer.c: in function `__find_get_block_slow&#39;:
  ld      fs/built-in.o
  cc      drivers/char/tty_io.o
in file included from include/linux/selection.h:11,
include/linux/vt_buffer.h:18:21: asm/vga.h: no such file or directory
make[1]: leaving directory `/home/nios/download/uclinux-dist/linux-2.6.x&#39;
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22731)
--- quote end ---
--- Quote End ---
You must disable these two console,
Device Drivers --> Graphics support --->
Console display driver support --->
[ ] VGA text console
< > Framebuffer Console support
