Insight
I'm running NIOSII v.5.0 with QuartusII v.5.0 on my Windows 2000 machine. The
installation of both packages was ok. I have built a .elf file containing my application (without use of NIOSII IDE) and I want to debug it using Insight (GDB)
from the Cygwin command line. I run Insight using the following command:
nios2-debug --cable=usb-blaster <myApplicationFile.elf>
On the console screen I see no error messages and my application is downloaded
into hardware memory. I&#39;m able to see the first two lines of my application. The
problem is concerning the commands to run the application. No commands work
and, if I try to type the commands on the GDB console, GDB doesn&#39;t reply also
when I type wrong commands. It seems GDB is not running
Please, can you help me ?
Best Regards
/Alessandro
--- Quote Start ---
originally posted by alessandro@Dec 21 2005, 01:02 PM
i&#39;m running niosii v.5.0 with quartusii v.5.0 on my windows 2000 machine. the
installation of both packages was ok. i have built a .elf file containing my application (without use of niosii ide) and i want to debug it using insight (gdb)
from the cygwin command line. i run insight using the following command:
              nios2-debug --cable=usb-blaster <myapplicationfile.elf>
on the console screen i see no error messages and my application is downloaded
into hardware memory. i&#39;m able to see the first two lines of my application. the
problem is concerning the commands to run the application. no commands work
and, if i try to type the commands on the gdb console, gdb doesn&#39;t reply also
when i type wrong commands. it seems gdb is not running
please, can you help me ?
best regards
/alessandro
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11704)
--- quote end ---
--- Quote End ---
If I remember correctly, nios2-debug is a vestige of the &#39;legacy SDK&#39; -- are you using that?
As an alternative I would suggest the direct approach - this is an excerpt from our eCos for Nios II document that describes loading & debugging via insight; there is nothing magical about an eCos .elf from one you create, so this should in theory work for you as well. Granted, there may be some tweaking required:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
8.2  JTAG debug using Insight
To debug an application using nios2-elf-insight, you should first launch nios2-gdb-server to establish a JTAG connection to the board. This is done by running the following command from within an SDK shell:
> nios2-gdb-server –-tcpport=2343 &
To debug an application named “hello” in the current directory, you should then run:
> nios2-elf-insight hello
This will launch the insight debug interface. To connect to the board, open the GDB console by selecting “Console” from the “view” menu. Then type the following commands:
> target remote :2343
> load
> break main
> jump *_start
This will: establish a connection to the target; download the executable; set a breakpoint at main; and then begin execution.
You can use these same commands when using nios2-elf-gdb in place of nios2-elf-insight.
From here, it is then possible to step, break, continue etc. You can find further information the Insight online help (select “help” at the top of the Insight window).[/b]
--- Quote End ---
Note that the above example assumes that "hello" is an .elf file... just without any .elf file extension.
Right.... and you can use other GDB-compatible debuggers, as well. ddd (http://www.gnu.org/software/ddd/) is a particularly nice one, if you&#39;re UNIX jock.
Cheers,
- slacker
