communicate uart with VB
sorry, my english is poor.
I transmit a wavfile to Nios II within MSCOMM32.OCX
baud rate=115200 bps
data bit=8
parity bit=none
stop bit=1
RECEIVER in Nios II IDE
 alt_16 buf;  for(i=0;i<160;i++){      fread(&buf, sizeof(alt_16), 1, uart);    //read data from file            if(buf==0x4F4B) break;    //"OK"            IOWR(USER_RAM_BASE, i, buf);    //write data to RAM and play sound  }
My transmitter transmit data to receiver, but receiver get only incomplete data.
eg. I transmit 0x2353, 0x6411, 0x4235, receiver get only 0x2353, 0x6435, etc.
I guess that transmit speed too fast and transmit buffer too small.
But I can&#39;t how to solve it.
thx
Orz
if the uart buffer is overloaded then data will get lost.
you should implement some handsahe between reciver and transmitter
the buffer i&#39;m using is 64bytes so the transmiter will not send more then 64 bytes until the reciver didn&#39;t signal that it can read more bytes
