12745 Discussões
Install older version of GCC compiler for HLS
Colaborador honorário II
1.521 Visualizações
I'm following the intel® high level synthesis compiler getting started guide for the Linux version it states that GCC compiler must be version 4.4.7 and newer ones are not supported.
I'm running Ubuntu 16.04 LTS and gcc version is 5.4.0.
How can I install the 4.4.7 version?
Thank you.
1 Responder
758 Visualizações
I have installed it from Ubuntu trusty repositories. I don't know if this is the optimal solution but it worked.
edit the apt sources file: sudo nano /etc/apt/sources.list
add the trusty repo at the end: deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
reload the sources: sudo apt-get update
install gcc 4.4: sudo apt-get install gcc-4.4
Responder
