12747 Discussions
Integration of custom logic block to NIOS2 using Quartus prime
Ak_3004
Can someone give me suggestions on how to integrate the custom logic block with NIOS 2 processor without making the custom logic as IP.
I have experience in integrating NIOS 2 by making custom block as IP so that it get adapted to NIOS environment. But, currently I need not want to make my logic block as IP rather than that I want to simply connect one of the outputs from my logic block to a PIO of NIOS 2. ow to achieve this?
Jeet14
You mean you don't want to use the Platform design tool to connect the IP block signals and the NIOS II IP?
Tiwari
Ak_3004
Actually in my FPGA there are two module, one contains NIOS core where we connect minimum required peripherals using platform designer and the other module constitutes of custom logic without NIOS core. Now I want to connect both of these modules together by generating the BSF files and establishing connection between them through line and bus node tool in BDF. I wanted to clarify whether the procedure I followed is correct. Any source of information regarding custom logic IP integration is highly appreciated, since, there is not much information available about this.
Ak
Jeet14
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Tiwari
Jeet14
I found one example reference for creating the generic IP component and interface with the NIOS II in Quartus.
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/b/b9/Generic_Component_As_Blackbox_Implementation.pdf
This is old example reference and you may need to try from your end.
Tiwari
Jeet14
Let me know if you have any further question on this.
If no then, I will proceed to close the case by today EOD.
Tiwari
Jeet14
