12745 Discussions
Intel HLS can not generate execution file
Hello,I am trying to use Intel HLS ,but it seems has some problem.
I have used windows7 and Quartus 17.1 pro.
This is my code:
# include "HLS/stdio.h" int main() { printf("Hello world!!\n"); return 0; }
My command :
i++ -march=x86-64 hello.cpp
and this is output :
C:/Program Files (x86)/Microsoft Visual Studio 10.0/VC/bin/link.exe : fatal error LNK1107: invalid or corrupt file :cannot read at 0x2A0 HLS Link x86-64 FAILD.
I also try to run the example Counter,used command :
i++ -march=Arria10 counter.cpp
and get the same output.Unlike the above, it generates a prj folder.
I had try to add C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin to the PATH ,
reinstalled Quartus and visual studio 2010.
None of these are useful.
Any help would be appreciated.
1.Have initialized the environment for HLS compiler?
2.Do You have any other version of Quartus installed on the machine?
Can you attach the log of command prompt?To get to know the steps followed.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
I have uninstalled Quartus 15,DevC++ and visual studio 2015 before I installed visual studio 2010 and Quartus 17.
There is only one version of Quartus 17 on the machine.
I first installed visual studio 2010 Professional ,and than installed Quartus 17.1. Finally, I have installed MinGW.
After the installation is complete, this is my command prompt:
Setting environment for using Microsoft Visual Studio 2010 x64 tools. C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>cd C:\intelFPGA_pro\17.1\hls C:\intelFPGA_pro\17.1\hls>init_hls.bat Assuming current directory (C:\intelFPGA_pro\17.1\hls\) is root of i++ Will use C:\intelFPGA_pro\17.1\hls\..\quartus to find Quartus for internal i++ use INFO: Could not find files for the given pattern(s). Will be using Modelsim at C:\intelFPGA_pro\17.1\modelsim_ase\win32aloem Will be using Modelsim at C:\intelFPGA_pro\17.1\modelsim_ae\win32aloem Adding C:\intelFPGA_pro\17.1\hls\bin to PATH Adding C:\intelFPGA_pro\17.1\hls\host\windows64\bin to PATH C:\intelFPGA_pro\17.1\hls>H: H:\>cd H:\test\counter H:\test\counter>i++ -march=Arria10 counter.cpp c:/program files (x86)/microsoft visual studio 10.0/vc/bin/link.exe : fatal error LNK1107: invalid or corrupt file :cannot read at 0x2A0 HLS Link x86-64 FAILD. H:\test\counter>i++ -march=x86-64 counter.cpp c:/program files (x86)/microsoft visual studio 10.0/vc/bin/link.exe : fatal error LNK1107: invalid or corrupt file :cannot read at 0x2A0 HLS Link x86-64 FAILD. H:\test\counter>i++ --debug counter.cpp EmitRawText called on an MCStreamer that doesn't support it, something must not be fully mc'ized aocl-clang: error: clang frontend command failed with exit code 3 (use -v to see invocation) HLS x86-64 compile FAILED. H:\test\counter>i++ -v counter.cpp Target FPGA part name: 10AX115U1F45I1SG Target FPGA family name: Arria 10 Target FPGA speed grade: -2 Analyzing counter.cpp Linking x86 objects c:/program files (x86)/microsoft visual studio 10.0/vc/bin/link.exe : fatal error LNK1107: invalid or corrupt file :cannot read at 0x2A0 HLS Link x86-64 FAILD. H:\test\counter>
To check if VS2010 installed properly.
Can you run the example in Quartus 17.1 using a build.bat file and check?
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
http://www.alteraforum.com/forum/showthread.php?t=58215
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
sThei
(-> https://forums.intel.com/s/question/0D50P00004C5jTsSAJ/)
I've got a similar error. I tried to run the example "counter":
cd C:\intelFPGA_pro\18.1\hls
init_hls.bat (->The i++ compiler is now available at 'C:\intelFPGA_pro\18.1\hls\bin\' (through your %Path%))
cd C:\intelFPGA_pro\18.1\hls\examples\counter
build.bat test-x86-64
i++ -march=x86-64 counter.cpp -o test-x86-64.exe c:/program files (x86)/microsoft visual studio 14.0/vc/bin/link.exe : fatal error LNK1107: invalid or corrupt file: cannot read at 0x320 HLS Link x86-64 FAILED. Run test-x86-64.exe to execute the test.
Any suggestions on how to solve that problem?
I'm using:
Quartus Prime 18.1.0 Patch 0.04
VS 2015 Update 3
Win 10 64Bit
