12748 Discussions
Interface Issue between Nios(uClinux) & User logic
My user logic is Simple Inverter.
The following C - code, which needs to have Read & write transaction with inveter is not Working. Means write is not properly happening.
main()
unsigned char *p,*u;
int a[100];
volatile int i,k=0,k1=0,k2=0;
p = 0x00800050;
k = k+1;
u = 0x00800054;
for ( i = 0; i < 100 ; i++ )
*p = i;
k++;k1++;k2++; // dummy statements
a = *u;
for ( i = 0; i < 100; i++ )
printf(" \n\t data_out: %d ", a);
Here P is the address for Write-port (Corresponding VHDL signal - din) , and
U is the address for read-port (Corresponding VHDL signal - dout)
But the following code works:
main()
int a[100];
p = 0x00800050;
k = k+1;
u = 0x00800054;
*p = i;
a = *u;
<span style="color:red">printf(" \n\t data_out: %d ", a);
printf(" \n\t Data_out: %d ", a[i]);
}</span>
As shown above, keeping a Printf statement is not possible for our application as it is inserting delay.
While configuring the User logic connection with Processor, I used Avalon_Slave_0 bus for Reading & Avalon_Slave_1 for writing. And there is no wait cycle kept there.
My VHDL code for User Logic is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Inverter is
Port ( clk : in std_logic;
reset : in std_logic;
cs : in std_logic;
wr : in std_logic;
din : in std_logic_vector(7 downto 0);
rd : in std_logic;
dout : out std_logic_vector(7 downto 0));
end Inverter;
architecture Behavioral of Inverter is
begin
process ( cs, clk,reset)
begin
if (reset = &#39;1&#39;) then
dout <= "00000000";
elsif ( clk&#39;event and clk = &#39;1&#39;) then
if( cs = &#39;1&#39; and wr = &#39;1&#39;) then
dout <= not(din);
end if;
end if;
end process;
end Behavioral;
So I am looking for a possible solution withoug inserting delay http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
You have to set bit 31 of the p pointer, to uncache the io access.
p = 0x00800050; => p = 0x80800050;
Hi Hippo,
Thank You Very Much.
That simple mistake created lots of confusion. Finally problem is solved.
K V Naresh
