12748 Discussions
Interrupt from external device
Hi from a new member.
I've interfaced an external device to Nios II using the "user logic" option. The external device is memory mapped, and the basic interface works OK...using the component editor I have successfully provided data, address, RdWrn, Wait, etc. I was able to peek and poke, as well as reading/writing with C code.
Once this worked, I wanted to have the external device's IRQn pin cause a Nios interrupt. I added an IRQn signal in the component editor, but...
no IRQn pin appeared on the SOPC symbol
no IRQ number appeared in the System contents IRQ column.
The conclusion I have reached is that adding the IRQn signal in the component editor pertains to the avalon bus, and that creating an external IRQ input pin is a separate matter.
I imagine I can accomplish this by implementing a single-bit PIO that interrupts on falling edge and connecting the external device to this pin. Is this the way to go? Is there a better way?
Thanks!
I used the older "legacy components ->interface to userlogic" and it
works with an external interrupt.
I simply setup the interface as following
Interface to user logic:
PORTNAME WIDTH DIRECTION SHARED TYPE
address 8 input yes address
write_n 1 input yes write_n
read_n 1 input yes read_n
data 8 inout yes data
chipselect_n 1 input --- chipselect_n
irq_n 1 output --- irq_n
After updating the symbol in quartus, there is the irq pin on the cpu symbol.
I think there seems to be some problems with the new component editor, so perhaps
try the old interface.
Perhaps somebody from Altera can answer this question,
i have read some problems about the new component editor, does it works ???
Thanks for reply.
Yes, that&#39;s basically what I did with the new component editor...the expected interrupt pin didn&#39;t show up http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
