Hi from a new member.
I've interfaced an external device to Nios II using the "user logic" option. The external device is memory mapped, and the basic interface works OK...using the component editor I have successfully provided data, address, RdWrn, Wait, etc. I was able to peek and poke, as well as reading/writing with C code. Once this worked, I wanted to have the external device's IRQn pin cause a Nios interrupt. I added an IRQn signal in the component editor, but... no IRQn pin appeared on the SOPC symbol no IRQ number appeared in the System contents IRQ column. The conclusion I have reached is that adding the IRQn signal in the component editor pertains to the avalon bus, and that creating an external IRQ input pin is a separate matter. I imagine I can accomplish this by implementing a single-bit PIO that interrupts on falling edge and connecting the external device to this pin. Is this the way to go? Is there a better way? Thanks!Link Copied
I used the older "legacy components ->interface to userlogic" and it
works with an external interrupt. I simply setup the interface as following Interface to user logic: PORTNAME WIDTH DIRECTION SHARED TYPE address 8 input yes address write_n 1 input yes write_n read_n 1 input yes read_n data 8 inout yes data chipselect_n 1 input --- chipselect_n irq_n 1 output --- irq_n After updating the symbol in quartus, there is the irq pin on the cpu symbol. I think there seems to be some problems with the new component editor, so perhaps try the old interface. Perhaps somebody from Altera can answer this question, i have read some problems about the new component editor, does it works ???- Mark as New
Thanks for reply.
Yes, that's basically what I did with the new component editor...the expected interrupt pin didn't show up http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
