12748 Discussions
Is there any way to support version feature?
Dear all,
Is there any way to put version information to a fixed address in FPGA configuration file and Nios' code?
In our system, we created *.rbf for FPGA configuration file and stored it into Flash, when system reset, Control Micro would configurate FPGA by reading *.rbf from Flash to FPGA. We hope there is a way to store version information into a fixed location of *.rbf file.
After finishing configurating FPGA, there exist a bootloader in onchipmemory, then the bootloader will read *.bin(Nios' code) from flash to SDRAM. Also, we hope there is a way to store version information into a fixed location of *.bin file.
Anyone Help?
Thanks in advance.
David http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Dear David!
May be you create service request to Altera directly?
Try it! It is more useful.
Thanks slave...
I have posted the SR.
If any update, I will share with all my friends...
regards,
David
Hi David,
what stops you from attaching a custom header/trailer that contains all the info you need?
Thats how we do it, apart from version info there is also an integrity check and
compatibility (SW/FW/HW revision) information. Same goes for NIOS software.
Cheers, Roger
Hi Roger,
Thanks for you reply.
Could you kindly help me clarfy your method in detail?
Thanks again,
David
Hi David,
You could look at the mkimage source from the u-boot project as an example:
http://cvs.sourceforge.net/viewcvs.py/u-bo...=1.17&view=auto (http://cvs.sourceforge.net/viewcvs.py/u-boot/u-boot/tools/mkimage.c?rev=1.17&view=auto
It adds a header that contains a timestamp & CRC-32 along with other information.
--Scott
Hi
Try and have a look on the entry on JTAG usercode. This gives you a way to parse an rbf file for the 32- bit JTAG usercode info that is generated or specified from within quartus.
http://forum.niosforum.com/forum/index.php?showtopic=3481 (http://forum.niosforum.com/forum/index.php?showtopic=3481
The method has only been tested for a ep1c6, but should provide a pointer.
