Welcome to Intel's forum.
I am glad you have successfully programmed your FPGA with the .v file you have but to indicate whether it is programmed like what you mentioned, you may go back to your project file directory, under the output file, check and see whether a .sof file is generated or not. But given your statement, I believe the .sof file is already in your output file directory and meaning it is successfully programmed to your FPGA.
Hope this could clear your doubts.
Thank you.
Kelly
Any updates on whether the information provided is useful and has solved your issue?
Looking forward to your updates. Thank you.
Kelly
I (NIOS2User) am unable to post with my previous account due to some issues in it and therefore I am posting with my other account.
I tried again to burn the code based on your provided information but still it is running the default program only with the conf light on.
Looking forward for your reply.
Thank you
The default code might be running instead of your verilog code. You may need to remove the default code .c file and replace it with just your coding file.
Another issue might also be related to your flashing methods of the code. May I know which flashing/booting methods have you used to program your Cyclone II?
Here is a reference for you to have a look on the correct booting methods for your project: https://www.intel.com/content/www/us/en/docs/programmable/683820/current/nios-ii-processor-booting-methods.html
Hope to hear on your findings.
Thank you.
Kelly
Any updates from your side on deleting the default code and only enable your coding file.
Have you also checked out on the booting methods as the issue might also rely on when your are programming your .sof/.jic file into your Cyclone II.
Hope to hear from you soon.
Thank you.
Kelly
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly
