Kernel Configuration
Does anyone know if you can use the configure.bat to configure a kernel for custom hardware? The list of hardware target platforms are very specific, and I don't know if you can use the tool to generate a kernel for my own hardware design. How do the device drivers get generated (addresses, irq, etc)? Does it get the information from the .ptf?
rppolicy
--- Quote Start ---
originally posted by rppolicy@Oct 24 2006, 09:17 PM
does anyone know if you can use the configure.bat to configure a kernel for custom hardware?  the list of hardware target platforms are very specific, and i don't know if you can use the tool to generate a kernel for my own hardware design.  how do the device drivers get generated (addresses, irq, etc)?  does it get the information from the .ptf?
thanks,
rppolicy
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18870)
--- quote end ---
--- Quote End ---
See nios wiki,
http://nioswiki.jot.com/wikihome/operating...x/linuxhwselect (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxhwselect
work in nios2 command shell,
or better , work on a Linux PC.
I found hwselect.pl* in a plugins/scripts directory, but when I run it in a bash window, I get a "command not found" error. I am VERY new to Linux, so do I need to do something before I execute it? Please help.
Thanks in advance,
rppolicy
Follow the uClinux guide in the nios wiki.
Put away your Windows.
And work on Linux PC.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif Still not getting anywhere. The Dev guide didn&#39;t seem to have any reference to hwselect. The hwselect.pl* exists, but I can&#39;t run it on the nios2 bash. We are planning on building a Linux dev station, but there has to be a way to get the hwselect.pl to run in the mean time.
Please reply...
rppolicy
