Wifi on uCLinux
Hi everybody,
Does anybody knows if it is possible to have WiFI working on uCLinux for NIOS when using a PCI Wifi card connected to the Altera PCI host Bridge. What options should be enabled during the kernel configuration ?
Regards.
Hi Bigboss25,
with PCI all generic 802.11b Cards will work.
The best way is to implement the Atmel 76C50x-Chip.
In the kernel config you just have to enable Drivers->Network->Wireless Lan and then the Hardwaredriver....
Bye
Marco
--- Quote Start ---
originally posted by bigboss25@Oct 5 2006, 09:49 AM
hi everybody,
does anybody knows if it is possible to have wifi working on uclinux for nios when using a pci wifi card connected to the altera pci host bridge. what options should be enabled during the kernel configuration ?
regards.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18564)
--- quote end ---
--- Quote End ---
--- Quote Start ---
originally posted by mabcom+oct 6 2006, 01:41 am--><div class='quotetop'>quote (mabcom @ oct 6 2006, 01:41 am)</div>
--- quote start ---
hi bigboss25,
with pci all generic 802.11b cards will work.
the best way is to implement the atmel 76c50x-chip.
in the kernel config you just have to enable drivers->network->wireless lan and then the hardwaredriver....
bye
marco
<!--quotebegin-bigboss25@Oct 5 2006, 09:49 AM
hi everybody,
regards.
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18570)</div>
[/b]
--- Quote End ---
Thx a lot Marco, but where can i find the hardware driver for uCLinux ? Is it possible to use a standard Linux driver (ie for MMU processors)?
Regards.
TO_BE_DONE
You may also try ZyDAS chipsets based wireless device on USB,
http://zydas.rapla.net/ (http://zydas.rapla.net/
There are Linux driver support on sf.net, and now included in kernel 2.6.18 .
--- Quote Start ---
originally posted by hippo@Oct 12 2006, 11:53 AM
you may also try zydas chipsets based wireless device on usb,
there are linux driver support on sf.net, and now included in kernel 2.6.18 .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18648)
--- quote end ---
--- Quote End ---
I have tested them, look at the second half of the wiki page,
http://nioswiki.jot.com/wikihome/operating...2%b5clinux/wifi (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/wifi)
--- Quote Start ---
originally posted by hippo+oct 27 2006, 02:20 am--><div class='quotetop'>quote (hippo @ oct 27 2006, 02:20 am)</div>
--- quote start ---
<!--quotebegin-hippo@Oct 12 2006, 11:53 AM
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18947)</div>
[/b]
--- Quote End ---
Nice work, again http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Thanx !
