- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I'm working on tring to run LCD 16207 driver on NIOS2 with MMU. The driver which is included in kernel and relased on this website: http://www.alterawiki.com/wiki/lcd_16207 is I mean for NIOS2 without MMU. When I try to load the module lcd_16207 I get kernel panic
root:/> modprobe lcd_16207 Device /dev/lcd16207 registered CPU 0 Unable to handle kernel paging request at virtual address 04001000, epc == c3c66000, ra == c3c6d0a4 Kernel panic - not syncing: Oops In source code I see the write function:static void WriteNios(unsigned long addr, unsigned long value)
(* (volatile unsigned long *)(addr))=value;
When module is tring run it, then kernel panic shows. I think this code is for no-MMU NIOS2. Is anyone who has successfully run lcd module on MMU Nios?
Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The 'Unable to handle kernel paging request' error sounds like you are running a system with an mmu.
A driver written for an mmu-less system won't work (actually, I'm not sure that one works anyway since that write probably need to bypass any data cache as well). You need to map the physical addresses into the virtual address space.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
All what you said I know. I'm asking if anyone worked with LCD 16207 on NIOS2 with MMU?
I'm wondering why drivers in uClinux are not marked which one is for MMU and noMMU NIOS2 version.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
