Low Level IO
Hi
I'm using Microtronix uClinux ver 2.6 for NiosII
I am trying to utilize the low level IO functions inb, outb etc in one of my apps. to read / write my hardware devices but I cannot build my project without getting "implicit declaration of inb..." etc. warnings
How do I access these IO functions from within user space in uClinux? Is there a user level io.h somewhere or can I set a compiler flag to access the kernel level functions???
Nick
Hi nipri,
inb(), outb(), etc. are defined in asm/io.h ... but they're normally wrapped with
an# ifdef __KERNEL__ ... this means they're intended for use by the kernel itself
(or loadable modules) ... pulling them into user-space apps is not recommended.
A device driver is where this type of hardware access is typically implemented.
That said, you can just define your own macros ... hoist them from the kernel
sources (or u-boot) into your app's source tree as they're normally just a set of
macros (see below) ... without an MMU, uClinux won't care.
--Scott
#define readb(addr)     ({unsigned char val;  asm volatile( "ldbio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define readw(addr)     ({unsigned short val;  asm volatile( "ldhio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define readl(addr)     ({unsigned long val;  asm volatile( "ldwio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define writeb(addr,val)     asm volatile ("stbio %0, 0(%1)" : : "r" (addr), "r" (val)) # define writew(addr,val)     asm volatile ("sthio %0, 0(%1)" : : "r" (addr), "r" (val)) # define writel(addr,val)     asm volatile ("stwio %0, 0(%1)" : : "r" (addr), "r" (val)) # define inb(addr)    readb(addr)# define inw(addr)    readw(addr)# define inl(addr)    readl(addr)# define outb(addr,val)    writeb(addr,val)# define outw(addr,val)    writew(addr,val)# define outl(addr,val)    writel(addr,val)
