12748 Discussions
LwIP Configuration problem
I follow the document " Using Lightweight IP with the NiosII Processor Tutorial " to optimize LwIP Throughput .
On page B-2 , it suggest that the optimal value of TCP_WND is 32768 . (The original value of TCP_WND is 2048 )
The TCP_WND effect the Maximum window size ( receive buffer space in bytes ) .
When I set the value of TCP_WND for 32768 , I can not receive total data that had been transmitted to my 1c20 board.
How to solve this problem ?
thanks a lot ~
I'm afraid you need to give a lot more detail if anyone is going to be able to help you. The best first place to start is to get a packet log using something like ethereal.
I use the simple socket server project which provided by NiosII IDE.
I modify the sss_handle_receive( ) in simple_socket_server.c and use sss_handle_receive( ) to receive data which sent by PC.
The sss_handle_receive( ) use the code as below to receive data .
rx_code = recv(conn->fd, conn->rx_buffer, data_length , 0);
For optimizing the LwIP Throughput , I use the NiosII IDE to set the value of TCP_WND .
When I set the value of TCP_WND for 32768 , the data I obtained is smaller than data_length .
But it is normal , if the value of TCP_WND is 2048 .
How can I do to solve the problem ?
thanks~
To solve a problem like this, you need to look at the packets actually being sent on the network. You need to get a packet log using a tool such as ethereal to narrow down where the problem is.
Dear rugbybloke
thank you~
I will try your suggestion .
you can look tt_nios2_lwip_tutorial.pdf file in altera\kits\nios2\documents
it is very helpful !
good luck to you !
