Make romfs, errors????????
Hi all.
when i make command(build kernel binarytoolchain with board 1c12 on linux): make romfs
===>some results:
er@localhost uClinux-dist]$ make romfs
echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /home/user/uClinux-dist/romfs/etc/version
make[2]: Leaving directory `/home/user/uClinux-dist/vendors/Altera/nios2nommu'
make[1]: Leaving directory `/home/user/uClinux-dist/vendors'
make[1]: Entering directory `/home/user/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/home/user/uClinux-dist/include'
make[1]: Entering directory `/home/user/uClinux-dist/lib'
/bin/sh: nios2-elf-gcc: command not found
make[2]: Entering directory `/home/user/uClinux-dist/uClibc'
[ -e /home/user/uClinux-dist/romfs/lib ] || mkdir /home/user/uClinux-dist/romfs/lib
if [ "" ]; then
romfs-inst.sh /lib/lib.so;
make[2]: Entering directory `/home/user/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entering directory `/home/user/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: cannot stat `boa': No such file or directory
make[3]: *** [romfs] Error 1
make[3]: Leaving directory `/home/user/uClinux-dist/user/boa/src'
make[2]: *** [romfs] Error 2
make[2]: Leaving directory `/home/user/uClinux-dist/user/boa'
make[1]: *** [romfs] Error 2
make[1]: Leaving directory `/home/user/uClinux-dist/user'
make: *** [romfs.subdirs] Error 1
- why command nios2-elf-gcc not found.
- file "init" created in directory romfs has problem:
I open file "init", it warns errors:"/bin/init" does not exist.
pls help me!!!!!!!!!!!!!!
thanks
make menuconfig
check if you have the correct target? Altera, nios2nommu, and Libc must be None.
Vendor/Product Selection --->
--- Select the Vendor you wish to target
(Altera) Vendor
--- Select the Product you wish to target
(nios2nommu) Altera Products
Kernel/Library/Defaults Selection --->
(linux-2.6.x) Kernel Version
(None) Libc Version
[*] Default all settings (lose changes)
[ ] Customize Kernel Settings
[ ] Customize Vendor/User Settings
[ ] Update Default Vendor Settings
Then <exit> <exit> <yes>
DO NOT change any other setting until first successful boot.
