I am running into a bit of a problem with the Managed Libraries. I have existing common code that I am trying to build into a library. But this code uses the types defined in alt_types.h. So, since this is part of the HAL, it won't build. This seems like a serious limitation. In the Software Dev, Guide it states that we should use these types and then Altera prevents us from using them in a library. I am totally off them mark here or should I just forget using Managed Libraries?
I think there is a little bug in the library makefiles that prevents the inclusion of alt_types.h . It is in one of the topics I sent recently on the forum.
go into components/altera_hal/build/lib.mk search the line <div class='quotetop'>QUOTE </div> --- Quote Start --- CPPFLAGS += -I.. -I$(GTF_GENERATED) $(foreach dir, $(HAL_INC_DIRS), -I$(dir))[/b] --- Quote End --- and change it in <div class='quotetop'>QUOTE </div> --- Quote Start --- CPPFLAGS += -I.. $(foreach dir, $(HAL_INC_DIRS), -I$(dir))[/b] --- Quote End --- ...and enjoy :-) ... in general, the standard libraries will allow you to include only the header files into altera_hal and altera_nios2. If you need more, you need some more hacking in the library makefiles :-) bye PJ- Mark as New
Thanks, I'll give it a try.
Has this been reported as a bug to Altera? Paolo.gai's post is from 15 months ago, yet we also just encountered this problem still in NIOS 6.0SP1.
It's amusing what goes wrong. When GTF_GENERATED is undefined the buggy line introduces a "-I" with no directory argument suffix. GCC then interprets this as an include directive using its space-separated syntax, and gobbles the the next valid -I<alteralib> directive as gibberish, thus removing the valid library path that ought to have been included. I'm always loath to modify the system files for fear of breaking on the next upgrade, so we've worked around this problem by predefining GTF_GENERATED as ".".
