12748 Discussions
Managing in software new SOPC Builder component
I work with Stratix. I've developed a new component in SOPC Builder.
I connected it to avalon slave. There are a couple of signals, which i assigned as global_signals.So there are 4 avalon_bus signals as following: READ_DATA, READ, IRQ and CLK (clock-to read the data stream while READ is assigned to 1, more exactely it clockes fifo chanel inside my component and READ enables fifo to be read).
Now I need to read the data at the software level. I do it with command:
p=(int *)CAM_INTERFACE_0_BASE;
a=*p;
// cam_interface_0 is my component name
the same result gives instruction:
iord(cam_interface_0_base, 0);
instantation in sopc shows 4bits mapping, that means base address: 0x01010820 and end address 0x01010823, do they show 16bits of read_data register? then what about irq and read registers? where they exist?
i don't know when can i read it, cause i don't know how to determinate if there is irq request from my ip, i don't know neither how to force read to be asserted.
i've checked through documentation, i see, there is ienable register, 'ctl3' in register file. how can i access it? can i try with nios2.h - nios2_read_ienable(..sth??..).
the 2nd problem is that when i read with for loop
for(i=0;i<a;i++)
a=IORD(CAM_INTERFACE_0_BASE, 0)
then every 2 data I read only 1. I verified this with signal tap. As I said before it is read from fifo. How can I menage this.
If you can recomend just some documentation or a piece of example codes i&#39;ll be really thankfull.
