MicroC/OS-II for Nios IDE5.0
Unlike in NIOSII IDE1.1, NIOSII IDE5.0 doesn't ship with MicroC/OSII Component. Where do i get it?
Thanks in Advance.
MicrosC/OS-II does ship with Nios II 5.0. However, as with Nios II 1.1, it isn't supplied with the evaluation version of the kit. You should contact your supplier to get the full version.
May I program with uC/OSII without NiosII IDE?
I remebered one of my friends once successfully implemented his design
in another C/C++ IDE,but then he was tickering with Nios3.0(not NiosII).
Under current NiosII IDE,may I program out of NiosII IDE and after
succeeful compilation then I copy that into the NiosII IDE?
hi,
u shd hanv full version of nios II IDE 5.0,u can also run without nios IDE,u can use nios SDK shell,type nios2-terminal in sdk shell.
