I have mounterd an NFS share to my board as: mnt -t nfs 13.1.143.56:/opt/files /mnt/nfs -n -o nolock and tried to copy a file that is 5 MBytes into a ram disk mounted at /mnt/ramdisk wich has a capacity for 8MB. The size of the copy file is always truncated to 4096 How can I get uClinux to copy the entire file? Please lend me a hand?Link Copied
I had a similar problem with reading, once I set the Block size to 1k for both r and write the problem went away.
Let me know if it helps --- Quote Start --- originally posted by carlos@Apr 14 2006, 11:15 AM hello,
i have mounterd an nfs share to my board as:
and tried to copy a file that is 5 mbytes into a ram disk mounted at /mnt/ramdisk wich has a capacity for 8mb.
the size of the copy file is always truncated to 4096
how can i get uclinux to copy the entire file?
please lend me a hand?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14382)
--- quote end ---
--- Quote End ---
