12745 Discussions
NIOS IDE compilation problem
IDE compiles all of source file in project working directory together.
Generally, software engineer saves revision files in same working directory.
for example, hello_world_v1.c
hello_world_v2.c --> a revision from hello_world_v1.c
then engineer want to compile only hello_world_v1.c
but IDE compiles all of file.
also, the files which user does not include files be included in the project automatically.
Could you explain this problem to me?
I don't know exactly where the NIOS IDE gets its information to compile everything, but I solved this by changing the extension (from .cc to .bcc for example).
With kind regards,
Jos
I want to say something:
If you want to build the certain project,right click on the project and choose build project ;you also set in perspective/preference/build order to fulfill your purpose.
Did you try to use CVS? it's also integrated into Eclipse...
bye
Paolo
