- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I tried to make a NIOS II Gen2 with a single on-chip ram
My flow is qsys-edit qsys-generate nios2g2.qsys --synthesis=verilog --simulation=verilog --output-directory=nios2g2 nios2-bsp HAL hal_bsp nios2g2.sopcinfo nios2-app-generate-makefile --bsp-dir ./hal_bsp --src-files nios2_test.c make but I get the following message at the last make: /altera/quartus/v14.0_web/nios2eds/bin/gnu/H-x86_64-pc-linux-gnu/bin/../lib/gcc/nios2-elf/4.7.3/../../../../../H-x86_64-pc-linux-gnu/nios2-elf/bin/ld: address 0x85d8 of nios2_test.elf section `.bss' is not within region `ram' I first tried to put code into rom and data in ram, but ran into a similar problem, and went with a single ram since I would assume it was simpler. The ram should be big enough: grep memorySize nios2g2.qsys <parameter name="memorySize" value="32768" /> Any idea's?Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
32k will only be big enough for the 'small' template examples.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks! That was indeed the problem. The program I used was tiny, but I only used default values for the bsp generation so I did not get any of the small libc stuff etc. I increased the size and it's working now.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
