12747 Discussions
NIOS II Quick Start tutorial issue
Hi
I am getting the following in the NIOS II IDE quick start tutorial, am I doing something wrong? I tried all the steps a couple of times...
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
I was trying to run the tutorial on 'standard' configuration from NIOS II IDE examples. I tried it with different configurations and different programs but still the same error is reported. Now I have not been able to run any program on the Altera DE2.
Please Help.
Guys:
I got the solution. There was error in pin assignments........
--- Quote Start ---
originally posted by napster@Jan 13 2007, 12:09 AM
guys:
  i got the solution. there was error in pin assignments........
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20545)
--- quote end ---
--- Quote End ---
I Have the same problem and get the same error message, too. Can you explain me your solution step by step? What is wrong with the pin assignments?
Thanx.
