Hi all,
I know that there are many posts on the same topic, but no post helped me in solving my issue.
I am having problem booting up my Nios C code from EPCS. I have NIOS II Faster Processor in my desing and using with Quartus 11.0 (also tried with Quartus 14.1) and Cyclone IV E as FPGA.
I have IPS-Embedded license bundle. In hardware I have 64Mb Serial Flash Device (EPCS64)
In logic I have instantiated
1. Nios II Faster Processor: Its Reset Vector is pointing to base address of EPCS Controller(0x1008_0000) with offset to 0x0000_0000. Exception vector to OCM base address(0x0002_0020) with offset to 0x0000_0020 (this offset is automatically generated).
2. EPCS Serial Flash Controller: This core is instantiated at base address 0x1008_0000.
3. PIO : in order to control LED operation. This core is instantiated at base address 0x0004_2020.
4. UART RS232 Serial Port: Instantiated at base address 0x0004_2000 for UART data transfter.
There is no external reset pin, the JTAG debug module reset out is connected to all reset inputs.
For the test purpose, I have a while loop in NIOS II application in which some prints are send to console and LED is blinked. LED is active low.
I generate .jic file using following steps:
1. First I generate Flash files using following commands
sof2flash --epcs --input="fpga.sof" --output="FPGA.flash"
elf2flash --epcs --after="FPGA.flash" --input="test.elf" --output="fpga_sw.flash"
2. I gerenerate .hex files as follows
nios2-elf-objcopy -I srec -O ihex fpga.flash fpga.hex
nios2-elf-objcopy -I srec -O ihex fpga_sw.flash sw.hex
3. Then Using Convert Programming Files in Quartus, I create a JIC file using the steps below:
a) Select EPCS64 (that is the flash chip i'm using)
b) Add flash loader as EP4CE40 (Cyclone IV E FPGA I am using)
c) Add sw.hex file with absolute address and start address is automatically given 0x0006_4E5F.
d) Add fpga.hex file with absolute address and start address is automatically given 0x0000_0000.
e) Then Generate .jic successfully
4. Then I flash this file on to the flash memory using USB-Blaster. Everything is fine till here.
But after restart I see that only FPGA Boots (LED is on), but NIOS does not (No prints on console and no LED blinks)
To test the working of desing and hardware, I changed NIOS II Reset vector to OCM and generated .sof file in quartus and .qip file in Eclipse using mem_init and then I included this qip file in the quartus project
and there after regenerated .sof file. When I load this .sof file directly on to OCM everything works just fine. I can see some prints are coming on console and LED is blinking.
Any ideas what is going wrong?
I am not sure about Reset vector and Exception vector offset values.
In some forum posts I have seen some people changed offset values and then it worked for them. But what should be the value of offset?
Thanks in advance
Best regards
Hi, Ganesh
May I know you intend to run your application directly from the flash ? or you intend to copy your application from flash to RAM and run from RAM ? do you have external RAM ?
Eric
Hi, Ganesh
You can refer to page 254 of below for reference.
It will demonstrate how Nios booting from EPCQ (or EPCS). The application can be copied to OCRAM using a boot copier.
Eric
Hi, Ganesh
Can I close this if you have no more inquiry ?
Eric
![](/skins/images/8C80966F940F80D854AEDDDACECA968C/responsive_peak/images/icon_anonymous_message.png)
Topic Options
