NIOS II/f core
I create system design based on NIOS II/s core (insrt cahe 512 bytes).
In my design programm and data memory located in SRAM (Cyc. dev board). RESET and ISR code in on_chip RAM.
My program work correctly (instr. cashe not used).
When I replace NIOS II/s to NIOS II/f core my programm start work incorrectly (not work lwip stack).
What reason for this behavior?
The are two potential reasons why your Nios II/f fails.
There is a known bug in the Nios II/f data cache in release 1.0 that shows up on Cyclone.
A fix for this bug will be released in a few weeks with the Nios II 1.0.1 release.
The bug is a rare case that only shows up in unoptimized code. So, as a quick experiment,
make sure all your code is compiled with optimization enabled.
The other possibility is that the data cache isn't being bypassed/flushed consistently by the software.
The Nios II/f uses a writeback cache so if software bypasses the data cache on a store and
then uses a normal load that reads the value from the data cache, the most-recent value
of that address won't be returned. This is not a bug in the data cache but is a bug in the software.
Can you tell me more about your SOPC Builder system and the software you are running?
Quartus design: VHDL full_featured
System libtrary: 1C20_full (altera full_featured design), single thread
Design compiler: Quartus 4.1 SP1
Fitter settings:
Physical synthesis effort: NORMAL
Perform physical synthesis for combinational logic = checked
Perform register duplication = cheked
Perform register retiming = cheked
Application: catted stand alone lwIP WEB server (removed all application calls), lwipopts.h by default.
Test task: checking PING function
Test options:
Linker: all memory place to ext_ram.
Optimization(NONE):
lib: -O0
app: -O0
Data cashe: 2KByte - passed
Data cashe:
1KByte - failed ( printf ("Application started.\n"); executed. )
1KByte(Set compiler options for lib & app to: -O3, -faster code) - failed.
1KByte(as prev., rwdata placed to SDRAM) - failed.
In the main code data cashe memory dirrectly not used!!!
int main(void) {     struct netif netif;     struct ip_addr ipaddr, netmask, gw;     unsigned int now, lasttime;     int i;# if IP_REASSEMBLY     int j;# endif  alt_avalon_lan91c111_if* dev_list_ptr =  (alt_avalon_lan91c111_if*)alt_ethernet_device_list.next;     printf("Example web server using Light-weight IP (LWIP)\n");     printf("and simple RAM-based file system.\n\n"); /* Initialize lwip */     lwip_init();     printf ("Setting IP address to: %d.%d.%d.%d\n", IPADDR0, IPADDR1, IPADDR2, IPADDR3);     printf ("Setting netmask to: %d.%d.%d.%d\n", NETMASK0, NETMASK1, NETMASK2, NETMASK3);     printf ("Setting gateway address to: %d.%d.%d.%d\n", GWADDR0, GWADDR1, GWADDR2, GWADDR3);     IP4_ADDR(&ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3);     IP4_ADDR(&netmask, NETMASK0, NETMASK1, NETMASK2, NETMASK3);     IP4_ADDR(&gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3);   netif_add(&netif, &ipaddr, &netmask, &gw,                                          (void*)dev_list_ptr,                                          lan91c111if_init,                                          ip_input);     netif_set_default(&netif);      /*Initialize application(s) */ /* * main loop to service the Ethernet device and expire TCP timers */  printf ("Application started.\n");  lasttime = get_milliseconds();       i=0;# if IP_REASSEMBLY     j=0;# endif     while(1)     {  lan91c111if_service(&netif);    now = get_milliseconds();  if (now - lasttime > TCP_TMR_INTERVAL) {      lasttime = now;      tcp_tmr();      if (++i==50) { /*etharp_tmr();*/ i=0;    }      } # if IP_REASSEMBLY      if (++j==1000) { ip_reass_timer(); j=0; }    # endif       } }
Any comments?
Don't forget to make things like this:
volatile declerations (volatile doesn't bypass cache anymore, but it should be done still since the compiler could synthesize that out).
