I have downloaded the NiosII linux port for the altera dev boards, Im wondering where you get the actuall hardware project that this SW runs on..! Cheers ArmlessLink Copied
Microtronix has ported the uClinux for three kinds of boards. The ciclone and stratix Altera´s develop. kit and it´s own dk. But remember that you have to recompile the kernel for the particular board you are using.
You can obtain the full schematics of the ciclone and stratix dk at the altera´s site.- Mark as New
What I ment was.. what HW configuration do you use..?
<The Altera dev kits come with a few examples!>- Mark as New
Be on the safe side and use a hardware design that uses the "f" core and the biggest surround hardware logic (would have everything, but might be overkill).
That's the best answer I can give since I've never seen one of these kits before.- Mark as New
It could be the same of the ones that came with the development kit, standart ou full version, VHDL or Verilog, whatever.
Vinícius.
