Am trying to simulate my design with the Modelsim, basically launched from SOPC builder. Am getting this design Error. Could anyone has a clue about this . error loading design vsim work.nios_core# vsim work.nios_core # ** Note: (vsim-3812) Design is being optimized...# ** Error: (vopt-23) Unable to change to directory path "altera".# No such file or directory. (errno = ENOENT)# ** Error: Failed to find design unit work.nios_core.# Optimization failed# Error loading design vsim work.nios_core# vsim work.nios_core # ** Note: (vsim-3812) Design is being optimized...# ** Error: (vopt-23) Unable to change to directory path "altera".# No such file or directory. (errno = ENOENT)# ** Error: Failed to find design unit work.nios_core.# Optimization failed# Error loading design vsim work.nios_core# vsim work.nios_core # ** Note: (vsim-3812) Design is being optimized...# ** Error: (vopt-23) Unable to change to directory path "altera".# No such file or directory. (errno = ENOENT)# ** Error: Failed to find design unit work.nios_core.# Optimization failed# Error loading designLink Copied
