New to NIOS
Hello all,
I am a moderately experienced fpga programmer but brand new to NIOS.
So, I have used SOPC to generate a NIOS II and designated onchip memory to go with it. From Eclipse I have been able to run the HelloWorld program (by linking to the .sopc file) and run the program onto the fpga.
Now, I want to know how to write code in main() to access the onchip memory in my NIOS II in the fpga.
Ultimately I want to write a register I define in my fpga so I can control things in my hardware from C code i write in eclipse.
I don't know where to start.
See chapter 9 of
Nios II Software Developer's Handbook
iowr_32direct
Please allow me to give you a bit more detail because I've been there and still not sure how to proceed.
I'm using the Nios II/e along with jtag uart, sysid and onchip memory.
My objective here is to write to the onchip memory a value that I can
access and pinout to an LED on my cyclone III fpga.
So 2 issues as I see it:
1) how do I actually write to the onchip memory from my nios II
(i.e what is the syntax of a write and do i need some external libs)
2) once i write to the onchip memory, how do i actually access that memory from outside of my sopc project. How do I interface with the rest of my fpga?? Currently my nios system only has a reset and a clock port. How in the world am I to access the contents of memory of the onchip memory and then connect that to a pin on my fpga?
nios_test_system_1
.clk_0 (clk40),
.reset_n (1)
For that particular action, you're going to want to instantiate an output PIO, 1 bit wide (assuming 1 LED), and hook it up to your LED at the top level.
In your Nios II code, you'd just use a PIO macro to write a 1 or 0 to control the LED. Look at the count_binary example for a decent sample of how to do this.
Cheers,
--slacker
thank you. that was exactly what i needed. i have my LED's blinking happily :)
