I am running SimpleSocketServer and cannot find where the IP obtained from dhcp server is stored? Thank you in advance
For the first net, probably here:
nets[0]->n_ipaddr, nets[0]->snmask, nets[0]->n_defgw- Mark as New
If you are using the Nios II console , you can see the DHCP address from the print out , somewhere between the "AutoNegotiation start" and "Simple Socket Server starting up ...".
I wanted to show it on lcd, thank you
Topic Options
