12748 Discussions
Nios IDE : Disabling Sysid Check
Can anybody tell me how to enable / disable the sysid check the nios ide does ?
i have a software project where i would like to temporarily disable the sysid check end enable ist again.
But i cannot find the "button" "checkbox" "setting" or what ever ....
I thought i had seen such a "switch" a while ago.
Michael
I do not know if that is a GUI setting, but you can modify the GUI generated script to ignore sysID. If you are willing to do some CLI-ing than search the forum for programming scripts.
IzI
--- Quote Start ---
originally posted by mschmitt@Nov 23 2006, 09:14 AM
can anybody tell me how to enable / disable the sysid check the nios ide does ?
but i cannot find the "button" "checkbox" "setting" or what ever ....
i thought i had seen such a "switch" a while ago.
thanks.
michael
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19595)
--- quote end ---
--- Quote End ---
Hi Michael,
You can disable Sys Id check from the IDE by doing the following :
From Menu : Run-> Run then in tab &#39;Main&#39;, uncheck &#39;Validate Nios II system ID before sowftware download&#39;
Regards.
THANKS !!
yes this was the mysterious button i was seeking for :-)
now i am happy :-)
Michael
