12745 Discussions
Nios II /e working and /f not working
GPete3
I made a very simple design like "hello world" that is perfectly running with the Nios II /e economy.
It takes place on a Max10 FPGA (Terasic DE10-Lite from Terasic).
When I switch to Nios II /f fast, I can compile etc, but when I lauch the C code, nothing happen.
Processor lauch but nothing appears in the console by JTAG.
I haven't got license (Quartus Prime Lite).
Could it explains why Nios II /f does't run ?
Do I have to buy a license to run Nios II /f ?
Thank you.
AnandRaj_S_Intel
The Nios II economy processor core, software tools, and device drivers are offered free of charge.along with Quartus lite.
but to use Nios II /f  you require license.
https://www.intel.com/content/www/us/en/products/programmable/processor/nios-ii/embedded-ip-suite.html
https://www.intel.com/content/www/us/en/products/programmable/processor/nios-ii.html
Anand
JOHI
New Contributor II
Did you download the time limited .sof file to your board after compilation? (i assume you do not have a licensed version of Quartus)
I had the same issue, I looked for 1 whole day to find the culprit.
Best Regards
Johi.
