Nios Problem
I create a new projcet in the Nios 2 IDE and if I build them.
I get the error:
make -s all
Creating /install.ptf...
sopc_builder: unable to locate Java runtime environment at - line 417.
Creating generated_all.mk...
27.04.2005 16:22:52 - (SCHWERWIEGEND) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalArgumentException: unexpected '(' in "ERROR in function ptf_to_list: java.io.FileNotFoundException: C:\Documents and Settings\rm099506\.sopc_builder\install.ptf (Das System kann den angegebenen Pfad nicht finden)"
make: *** [system_description/../obj/generated_all.mk-t] Error 1
Build completed
Thanks!
