uClinux feature support
Small question to NIOS2 uClinux users...
Has anyone used, nios2 uClinux with initrd support or RAMDisk ?
Is anyone using any alternative other than romfs.img support mounted as
readonly-root fs supplied as part of evalutaion kit ?
Any alternative suggestions to mount and use a r/w filesystem will be deeply appreciated.
Here is something you can try if you want to use a RAMdisk as the root fs:
Busybox comes with the chroot and pivot_root utilities, so you can use those to change the root fs to your RAMdisk once it is mounted.
What you have to do is create a ramdisk image that has all the files and directories needed for your root filesystem.
A ramdisk image can be created on a Linux host as shown:
dd if=/dev/zero of=/dev/ram0 bs=1k count=2048 /sbin/mke2fs -s0 -vm0 /dev/ram0 2048 /sbin/tune2fs -i 0 /dev/ram0 mount /dev/ram0 /mnt rmdir /mnt/lost+found { populate your filesystem here} umount /mnt dd if=/dev/ram0 of=ramfs2048 bs=1k count=2048 ./holes ramfs2048 > ramfs2048.img
The holes utility compresses the ramdisk image, here is the source for that utility:
/* make a file with holes */ # include <unistd.h># include <stdlib.h># include <stdio.h># include <sys/types.h># include <sys/stat.h># include <fcntl.h> char buf; int main(int argc, char *argv) {  int count;  int pos;  int zcount;  int b;  int len;  int in = open(argv, O_RDONLY);    len = lseek(in, 0, SEEK_END); fprintf(stderr, "TOTAL LEN=%x", len);    lseek(in, 0, SEEK_SET);    len = htonl(len);    write(1, &len, 4); fprintf(stderr, "\n", len);  pos = zcount = count = 0;  while(read(in, &buf, 1) > 0) {    pos++;    if (count || buf) {      count++;      if (buf == 0)        zcount++;      if ((zcount == 8) || (count == 2048)) {          b = htonl(pos-count);          write(1,&b,4); fprintf(stderr, "POS=%x:", pos-count, b);          b = htonl(count);          write(1,&b,4); fprintf(stderr, "LEN=%x", count, b);        write(1,buf,count); fprintf(stderr, "    -->   DATA=%x\n", buf);     count = zcount = 0;      }    }  }  if (count) {    b = htonl(pos-count);    write(1,&b,4); fprintf(stderr, "(%d)=%x\n", 4, b);    b = htonl(count);    write(1,&b,4);    write(1,buf,count); fprintf(stderr, "(%d)=%x    -->   (%d)=%x\n", 4, b, count, buf);  } }
Once you have your ramdisk image, you can include it in your Microtronix Nios II Filesystem Project. You can then edit your /etc/inittab and /etc/init.d/rcS files to use pivot_root and chroot on start up to switch the root filesystem to a RAMdisk during start up.
For example, your /etc/inittab file might look something like this:
::askfirst:-/bin/sh ::sysinit:/etc/init.d/rcS
And your /etc/init.d/rcS file could include something like this :
...# for pivot root /bin/expand /ramdisk.img /dev/ram0 /bin/mount -t ext2 /dev/ram0 /mnt/ide0 -n cd /mnt/ide0 mkdir old-root pivot_root . old-root exec chroot . sh <dev/console >dev/console 2>&1 umount /old-root ...
