I create a new projcet in the Nios 2 IDE and if I build them. I get the error: make -s all Creating /install.ptf... sopc_builder: unable to locate Java runtime environment at - line 417. Creating generated_all.mk... 27.04.2005 16:22:52 - (SCHWERWIEGEND) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalArgumentException: unexpected '(' in "ERROR in function ptf_to_list: java.io.FileNotFoundException: C:\Documents and Settings\rm099506\.sopc_builder\install.ptf (Das System kann den angegebenen Pfad nicht finden)" make: *** [system_description/../obj/generated_all.mk-t] Error 1 Build completed Thanks!Link Copied
