Nios V uC/TCP IP Failed
JLee25
Hi support,
  I am learning the simple socket server design on Cyclone 10 GX.
For unknown reason, the initialization process stopped with the error code (2010),
It's the TSE with DP83848.
The signals on MDIO and MDC is working.
Therefore I would like to know how to debug this issue.
Thank you.
BRs,
Johnson
JingyangTeh_Altera
Hi
Did you managed to run the example design on the Cyclone10 EVB yet?
Please note the following setting when trying to generate the BSP for the application.
5.5.2.2. Configuring the BSP (intel.com)
For the application you could reuse the application code from the latest design example.
https://www.intel.com/content/www/us/en/design-example/776159/intel-arria-10-fpga-simple-socket-server-for-the-nios-v-m-processor-design-example.html
Jingyang, Teh
JingyangTeh_Altera
HI
I am Jingyang and I will be taking over the case from Eber.
Sorry for the late response as there are a surge in cases at the moment.
Please give me sometime to try get the example design running and try probe the behavior of the ff_rx_rdy pin.
Jingyang, Teh
JingyangTeh_Altera
Hi
Sorry there is a current surge in case and I will need more time in this case.I managed to run the example design and able to connect to the board through Telnet. Currently I will need more time to acquire the signalTap waveform.
Previously when you switch the Example Design to DHCP. Are you able to connect to the board through Telnet?
Jingyang, Teh
JLee25
Hi Jingyang,
  Thank you for the update.
So you can run the example design on the Cyclone 10 GX device and can telnet it?
If this is the case, would you share me the example?
As I never have any change to connect to the board.
BRs,
Johnson
JingyangTeh_Altera
Hi
I tried it on an Arria10 board. I think it should be okay if we migrate it over to the Cyclone10.
Attached is my project for the Arria10.
Let me try to migrate it to the Cyclone10 board and share u the project again.
Jingyang, Teh
JLee25
Hi Jingyang,
I hope to receive the C10 project soon.
BRs,
Johnson
JLee25
Hi Jingyang,
  Do you have any update on the C10 project?
Thank you.
JingyangTeh_Altera
Hi
Sorry for being so slow.
I got a hard time getting your project to work .
I think in your project you did not assigned the pins correctly.
Still trying to migrate and testing out the example design.
attached is so far i managed to get the application running boot into initialization.
Still solving the error code 20014 that i am looking at.
Jingyang, Teh
JLee25
Hi Jingyang,
  I just saw the update.
After download the qar but I can't open it at Quartus Pro 23.2..
By the way, what's the error code 20014 you mentioned?
It's in my previous shared package?
BRs,
Johnson
JingyangTeh_Altera
Hi Johnson
Could you try with the latest 23.4 Quartus?
I have migrated the latest NiosV example design to the cyclone10 gx board.
I managed to solved the error code 20014.
Now i am stuck with the same error code that you are facing. 2010
Right now i am asking around what could be the cause for this.
Jingyang, Teh
JingyangTeh_Altera
Hi
I managed to get pass the error. It seems that in the previous design I did not connect the reset for the ethernet phy.
Please find the latest project with the correct pin placement.
You would need to assign these pin in the pin planner.
Screenshot of the results
Jingyang, Teh
JLee25
Hi Jungyang,
Let me check on the C10 EVB and get back to you my finding later.
BRs,
Johnson
JingyangTeh_Altera
Hi
Jingyang, Teh
JLee25
Hi Jingyang,
  Thank you for the link..
I can see the example running now.
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
