12748 Discussions
Nios custom component I/0 problem in DE2
Hi all,
I have added a simple component using SOPC Builder. The signals of the component are as follows
Port (         clk   : in std_logic;         reset : in std_logic;  cs    : in std_logic;      wr    : in std_logic;         din   : in std_logic_vector(31 downto 0);  rd    : in std_logic;            dout  : out std_logic_vector(31 downto 0) );
I assigned clk and reset to global signals clk and reset.
cs, wr, din are assigned to chipselect, write and writedata of avalon_slave_0 interface and
rd, dout to read and readdata signals of avalon_slave_1 interface.
I perform input when cs and wr are high. But i find that cs and wr are never going high. I use following code to perform input and output.
     en <= cs and wr;     --Process for Input and output       process ( en, clk, reset)     begin     if (reset = &#39;1&#39;) then     data_in <= (others => &#39;0&#39;);     elsif (clk&#39;event and clk=&#39;0&#39;) then  if ( en = &#39;1&#39;) then      data_in <= din;  end if;                dount <= data_in;      end
I access the custom logic using a C program. I run uClinux on the top of Nios processor. My C application runs on uClinux. My C program is very simple and just writes and reads the data. Program is shown below
main() {   int *p,*u;   int i,k=0;   p = 0x0090002C;   u = 0x00900098;   for ( i = 0; i < 10000; i++ )   {          *p = i;       printf(" \n  Data_out: %x ", *u);   } }
the same setup was working on stratix1s10 board. But it is not working on DE2 board. I tried read and write wait cycles of 0 and 1 for avalon interface. I tried sampling on negitive edge and also tried on positive edge. Nothing is working.
Can anyone help me.
I am sorry. I forgot to set the uncache bit. Now everything is working fine.
sorry for the post.
Mythri.
--- Quote Start ---
originally posted by mythri@Nov 4 2006, 06:18 PM
hi all,
      i have added a simple component using sopc builder. the signals of the component are as follows
port (         clk   : in std_logic;         reset : in std_logic;  cs    : in std_logic;      wr    : in std_logic;         din   : in std_logic_vector(31 downto 0);  rd    : in std_logic;            dout  : out std_logic_vector(31 downto 0) );
i assigned clk and reset to global signals clk and reset.
i perform input when cs and wr are high. but i find that cs and wr are never going high. i use following code to perform input and output.
     en <= cs and wr;     --process for input and output       process ( en, clk, reset)     begin     if (reset = &#39;1&#39;) then     data_in <= (others => &#39;0&#39;);     elsif (clk&#39;event and clk=&#39;0&#39;) then  if ( en = &#39;1&#39;) then      data_in <= din;  end if;                dount <= data_in;      end
i access the custom logic using a c program. i run uclinux on the top of nios processor. my c application runs on uclinux. my c program is very simple and just writes and reads the data. program is shown below
main() {   int *p,*u;   int i,k=0;   p = 0x0090002c;   u = 0x00900098;   for ( i = 0; i < 10000; i++ )   {          *p = i;       printf(" \n  data_out: %x ", *u);   } }
the same setup was working on stratix1s10 board. but it is not working on de2 board. i tried read and write wait cycles of 0 and 1 for avalon interface. i tried sampling on negitive edge and also tried on positive edge. nothing is working.
can anyone help me.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19160)</div>
--- Quote End ---
--- Quote Start ---
originally posted by mythri@Nov 4 2006, 08:48 AM
hi all,
can anyone help me.
--- Quote End ---
Hi,mythri
I&#39;m Nios Newbie. I want added a simple component using SOPC Builder.
Can you give me a complete simple example?
thanks.
faye
