12748 Discussions
Nios systems - programing EPCS
Hello experts
I have build nios2 board and it work just fine - no problem with it.
But in software tools to many problems
So we are using command line to compile and download SW code to EPCS but
we don&#39;t understand how to download HW code to EPCS from command line http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Can you explain or just show command line how to download HW+SW into EPCS ?
Hi Alexs,
Good explanation in Nios2 flash programmer guide.
-Baycool
Hi AlexS,
for your sw elf file (sw.elf):
$ elf2flash --epcs --base=0x0 --end=0x7fffffff --input=sw.elf --output=sw.flash
$ nios2-flash-programmer --epcs --input=sw.flash --sof=<PGM>
for your hw sof file (hw.sof):
$ sof2flash --epcs --input=hw.sof --offset=0x0 --output=hw.flash
$ nios2-flash-programmer --epcs --input=hw.flash --relocate --sof=<PGM>
The <PGM> is the sof file for your flash programmer design.
--Scott
